Casinojunkie's avatar
Casinojunkie
Freezer frosting up?
I have a Norcold refrig. with upper freezer in my 5th wheel.
My problem is that the freezer keeps getting frost on the back wall very quickly.
Temp in the freezer section is 0 to 10*.
What could be the problem and how to fix it.
  • That's a good thing it's working. Most of these devises are not frost free like your home refrigerator. I have to defrost mine about every 3-4 weeks depending on build up. The more you open the door and how humid it is all contribute to how often you need to defrost.
    I have several insulated bags that I put the cold/frozen stuff in so I can get it defrosted as quickly as possible with out it melting. I like to use a fan on a stool to speed up the defrosting.
    Bill
  • Frost is caused by excessive humidity in the air. When you open and close the freezer, this air enters the freezer and the moisture condenses on the freezer wall as frost. The only real way to minimize it is to run a dehumidifier in the FW.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
