Rock2's avatar
Rock2
Freezer has not reach down to zero
I have Norcold - Model # N821FLT. Refrigerator temp works fine 40 degree but freezer has not reach down to zero. I increased setting from 4 to 8 last night. I use Multimeter Clamp to test heating tube. It came out between 1.2 and 1.4 AMP. I would think the heating tube works fine? Made me wondering if it is time to replace heating tube? Any advise would be appreciated. Thanks Advance?
  • Dutch_12078 wrote:
    Does it work any better on LP?
    I have thought about it. I will wait tomorrow if not improve then will switch LP.
  • Old-Biscuit wrote:
    What temp is freezer at?
    Electric heat element is a 300W rated at 2.5A - 2.7A with 120V AC
    Fan in outside compartment.........working?
    As present time - Outside temp is 81 degree. Earlier afternoon the fan kicked on. But now fan is not running. Eastern time 2000. Refrigerator remain the same 40. Freezer 20 degree. (Amp - 1.4) I turned down setting to 5. Voltage - 112 AC.
  • I was never able to keep ice cream solid in an LP fridge.
  • Why does it need to reach zero? We keep ours between 15 and 20F.
    Bill
  • I can't give any advice about heating tubes (because I don't know) but here are our cool down temps and times on a 821. Something to compare with?
    Here are the cool down temps: (using elec not propane. Will do propane next defrost time)
    Time............Fridge.................Freezer
    750PM...........78.....................78
    906Pm...........66.....................46
    1010pm..........59.....................16
    1108pm..........51......................7
    1200 midnight...47......................-1
