maillemaker's avatar
maillemaker
Freezer works, refridgerator doesn't.
Refrigerator is an 876EG2 Norcold. It is 28 years old. The back wall of the freezer reads 9F after running 4 hours, the fridge cooling fins read room temp (85F).
I assume this is a blockage in the cooling system and the unit is unrepairable?
Steve
  • Try a battery operated fan in the fresh food section. Works for me. That’s what I figure.
  • I was on a week-long camping trip two weeks ago. I pre-loaded the fridge with frozen food in the freezer. The freezer stayed super cold (fog inducing) for the duration of the trip, but the fridge compartment never got cold.
    I figured maybe with putting all the pre-frozen stuff in the freezer the fridge thought it was cold enough and quit trying to cool anything at all.
    Steve
  • The original refrigerator in my 96 Southwind works and does a good job.
    I let it run for 24 hours before I check the temp.
    Like Old-Biscuit said, be patient.
  • Patience...
    Freezer has to get COLD first BEFORE food compartment can even begin to cool down
    Freezer at 9*F is at temp that food compartment can start cooling down
    Give it 12 hrs and then check food compartment temp using a bulb thermometer in glass of water sitting on shelf
    IF after 12 hrs freezer is still colder and food compartment is not at 40*F (fins S/B 10*F colder) then you may have a blockage in cooling unit between LOW temp evap (freezer) and the HIGH temp evap (food compartment)
  • DrewE's avatar
    DrewE
    Explorer III
    Check it after maybe twelve more hours. It takes a good little while for RV fridges to cool down. I think typically the coolant goes into the freezer heat exchanger thingy first and then works its way down to the fridge. Since you're getting cooling in the freezer, the cooling unit is clearly operating.
  • Absorbtion fridges can be extremely slow. Try putting a few things in there that are already cold, 2litre sodas from the house, maybe a bowl of ice , give it a overnight and check it again tomorrow.
