WyoTraveler
Sep 18, 2013Explorer
Do you know if your tanks are heated? Depends on the RV. If your tanks are enclosed and heated the worse thing you can do is run a space heater. The RV furnace will heat your tanks a space heater won't. If I am in warm weather and the temp drops below 10 degrees I winterize. I blow out with air. Takes about 10 to 15 minutes. If I am camping for a short time in cold weather I keep it winterized. I flush the toilet using antifreeze. Carry bottled water for washing and cooking.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
