Old-Biscuit
Jan 05, 2020Explorer III
ScottG wrote:
The water pump functions as a check valve and it isn't working right.
Most of the time the problem is the pump has sucked up a piece of junk from the tank (plastic bits form assembly).
If you're handy, simply take the head of the pump apart and rinse all the parts off (water off of course).
You probably wont even see the problem but it will work afterwards. If not, you're not out anything.
Possible ----could be check valve inside the pump (single diaphragm)
BUT OP didn;t have the problem UNTIL he messed with the FILL Valve
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
