avarusbrightfyr
Jan 08, 2020Explorer
I'm still working on getting things replaced, but I think I might start using the RV side primarily and just using city water to fill the tank. I still have to do weekly emptying of my black tank anyway, so it wouldn't be that much of a change. It will also keep the pump from sitting for long periods without being used, and I've noticed that in general mechanical parts don't like to just sit unused.
As of right now, I've bypassed my selector valve and have the water inlet connected straight to the hose that goes to the plumbing fixtures. I'm slowly collecting parts to put everything back together mostly the way it was, except that I'm going to use screw on connectors for the selector valve connections instead of clamps or crimps. That way I can just unscrew everything if I need to take the valve out in the future.
It also turns out that my water pump is bad, so I have a replacement coming in for that as well. It really sucks because it's barely been used at all...like a few times for demo before purchase, and this one time when I was testing everything out. I'm taking this opportunity to install a dc connector plug so that the only wiring I have to do for future replacements is on the pump side and it will just plug right in.
While no one is every happy to have to fix things, part of me is glad this happened now so I can figure out how all this works while I have easy access to parts and city connections.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
