opnspaces
Jan 08, 2020Navigator III
I agree on that. It's way better that you found this now than two hours away out at a remote campsite.
If you are retaining the PEX (hard plastic lines) be careful with the worm drive hose clamps. They are easy to strip when tightening enough to compress the PEX. Home Depot will have the crimp rings and crimpers for the PEX lines in the plumbing section if you want to go that route. Also if you are using flexible lines make sure they are rated to handle the city water pressure. Up in my neighborhood I've seen 120 lbs pressure coming off the street. So I always use a pressure regulator when I hook up to city water.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
