avarusbrightfyr
Jan 11, 2020Explorer
Another update: I got all my plumbing hooked up the way I want it and now everything works as it originally did, but now everything is screw on and easily removable if needed. It turns out the the flair-it fittings aren't sized for braided 1/2 PEX and it wouldn't fit, and that was giving me a lot of grief until a friend suggested I soak the end in really hot water to make it more flexible. That did the trick and it took like ten minutes to get everything finally hooked up again.
I did do some troubleshooting before hooking up the tank fill line, however. I ran water with the valve set to city and there was no leakage from the tank fill side of the valve even when under city pressure. This leads me to believe that the suggestion that the water pump leaking back into the tank was the correct one. I already have a replacement pump on order and it arrives next week, so we'll see if this solves the unwanted tank filling issue and my trailer is back to 100%.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
