avarusbrightfyr
Jan 11, 2020Explorer
opnspaces wrote:
I agree on that. It's way better that you found this now than two hours away out at a remote campsite.
If you are retaining the PEX (hard plastic lines) be careful with the worm drive hose clamps. They are easy to strip when tightening enough to compress the PEX. Home Depot will have the crimp rings and crimpers for the PEX lines in the plumbing section if you want to go that route. Also if you are using flexible lines make sure they are rated to handle the city water pressure. Up in my neighborhood I've seen 120 lbs pressure coming off the street. So I always use a pressure regulator when I hook up to city water.
I am retaining all the PEX connections and so far nothing appears to be leaking at all. Ideally I won't have to deal with this again for a very long time, but I'll look out for stripping things next time. The entire trailer is using braided PEX, so I think it's beefier than the thinner stuff.
I did a lot of research before buying my trailer and I do have a pressure regulator that is set to around 55 PSI, which is what my pump maxes out at as well. I'm currently only getting 40 from the city, though. San Diego isn't great for water pressure.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
