avarusbrightfyr
Jan 14, 2020Explorer
Ok, so this should be the final update. I got the new pump installed and the fresh tank does not appear to be filling after sitting overnight. Pump works and runs fixtures, city water works and runs fixtures. Looks like the issue is solved for now. In the end, it looks like the pump was the original culprit.
However, I'm not comfortable yet because one of the flair-it fittings started leaking. I don't know if it was a bad connection or if it's a failing in the design or what. I replaced the leaking one with a crimp fitting and it seems to be fine now. Just a shame that it started while I was at work and there's some water damage. I'll be keeping an eye on it for the next couple of weeks.
Thanks to everyone for the help!
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
