Dusty_R's avatar
Dusty_R
Fresh water hose
I grew up on a farm, where we had live stock, and used common water hoses from local hardware stores.
We often drank from those hoses, with no problem.
We have had a mh for many years, and used the white hoses recommend for drinking water.
The last couple of years these white hoses have been causing a bad taste when using for city water hook ups. Not at any one location, but every time we use the city water hook up.
Filling the fresh water tank has not been a problem.
Has anyone found a hose that does NOT leave a taste? Even after a few years of use.
Thanks,
Dusty
  • Let the water run for a few seconds to remove the water that's been sitting in the sun in the hose. Filling the tank works because the water is constantly moving.
  • I use my water tank exclusively and just re-fill it when I need to. Flush the hose, fill the tank, and done; repeat as needed, no bad taste.
  • Valterra and make a "taste free" potable water hose. There's a number of potable water hoses available that have an inert plastic that won't impart a bad taste to the water and that also meet NSF & ANSI requirements. I believe the taste free ones all have a blue tracer line along them to identify them. Have also seen them sold as commercial food grade hoses.
    Note: The taste free hoses tend to be stiffer and need to be coiled with a larger radius. We have one that has a permanent kink in one spot because I tried to coil it like our old standard hose. Can't get rid of the stupid kink now. Annoying!
  • For the RV I replace the potable water hoses every 3 yrs.
    They ALL seem to get funky.......and I grew up drinking out of rubber yard hoses, swimming/swallowing pond water, playing in the run off from irrigation etc.
    We fill fresh water tank and use it for everything.
    But even with an in-line charcoal filter the hoses leave I slight taint.
    Tires/water hoses.....replace routinely :B
  • The white hose is made from virgin non-leaching materials. Ordinary garden hose may contain recycled materials that could leach unknown compounds, or even a new ordinary garden hose made with leaching compounds. Just stick with the white hose.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
