Almot
Feb 12, 2017Explorer III
magic43 wrote:ksg5000 wrote:
Another possibility - check the inlet filter. Sometimes that can get plugged up which prevents water flow - mine was filled with plastic shavings likely from the holes Fleetwood drilled into the plastic tank when setting up the FW tank.
And yet another possibility. My camper did not have a filter and the shavings were inside of the pump preventing the valves from closing. I took it apart, cleaned out the plastic shavings and installed a filter to prevent future problems.
Had this too! :) My pump has a tiny strainer, but it was all full with plastic shavings that workers ALWAYS leave in the pipes, in a new trailer. Didn't completely block the water flow but slowed it down a lot.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
