geneeich's avatar
geneeich
Fresh water tank back filling thru pump
I am having a problem where the fresh water tank is filling while hooked up to city water. I think is must be coming thru the check valve in the pump. Does anyone know if the hole pump has to be replaced or can only the valve be replaced. I have not researched the pump on line, just looking for some general info.
Thanks for any help and guidance.
  • wnjj's avatar
    wnjj
    Explorer II
    Adding a check valve seems like a hack to me. If the internal pump check valve is leaking, that means the pump isn't working to its full potential. It uses check valves to push the water toward the outlet.
  • beemerphile1 wrote:
    Simply turning the pump on may dislodge the particle that is causing the check valve to leak.
    Exactly.....
    2016 RV so most likely plastic debris from fresh water tank/pump installation
    Use pump for water needs instead of city water and use up the WHOLE fresh water tank.
    Then swap back to city water-----disconnect suction line on pump and see if it still is back-flowing thru pump
    If it still is.......warranty/replace pump
    OR
    buy a $15 in-line check valve and install it in suction line.
    (Shuflo makes an in-line)
    Cheaper/easier then pump rebuild
  • Simply turning the pump on may dislodge the particle that is causing the check valve to leak.
  • local DMV had a sign that said
    "NO WIFI"
    Available
    I inquired about this "NO WIFI" that is available, to no avail...
  • 2oldman wrote:
    Looks like you don't have to replace the 'hole' pump.
    I've never pumped "holes" - must be something new in campers. :W
  • You haven't provided any pump details but if a failed check valve in the pump head is truly the problem I'd just add an external check valve and be done with it.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Feb 01, 2025
