- Wolfman_JacquesExplorerItchey Feet: Exactly! That is also what I think. Where is that valve? All the waterline that i can see doesn't have a check valve. Is it in the external plate?
- opnspacesNavigator IIIMine does that from time to time. When I notice it happening I just screw the garden hose on and run the sink for a second or two. That has so far always reseated the leaking valve.
- Itchey_FeetExplorerThe check valve on the city water hookup is cocked to the side or broken. It is the check valve that lets you build water pressure.If you turn on the water pump and go out and look it will probably be squirting water. JMHO
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
