ginaseven's avatar
ginaseven
Fridge does not come on.
My fridge has been working fine all day. Plugged everything in and turned on a couple of days ago to start loading for a trip this weekend. It was on a couple of hours ago and cold when I was putting food in. I just went out to put something in and it is off. It is still cold. I am plugged in at home. Just to a regular outlet, only to run the fridge and lights when loading.Everything else works. I have checked fuses and breakers. All are ok. I am not terribly tech savvy unfortunately. Is there anything else I can check? We are supposed to head out at 8 am tomorrow.
Thanks!!
  • yes start at the battery even thow your plugged in the frig needs a good battery to work. and you could call a local rv tech service in your area they come to your site.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There is a cable from the circuit board on the "Backside" (Outside black box lower left) and the "Eyebrow" (where the lights are) Straight cable. connector on each end.. A few years ago I had to unplug and re-plug both ends a few times and that fixed it.
    There are fuses in that black box as well.
  • Mine was a fuse on the main panel board beside the AC breakers. Replaced it and all has been well since.
    I wold recommend doing an easy check like that before delving into the complicated stuff.
  • We are assuming he has 12v except for the fridge.
  • Look at my post this week in tech forum. I had similar problem. Mine happened while in transit. I’m still working on it but making progress.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
