- basscatlildaveExplorerThere is no threads. It's just a heating bulb that should slip in a holder. The old one was so rusty it had to be drivin out.
- Jim-LindaExplorer II
Ex-Tech wrote:
I would use caution on the anti-seize.
The heating element needs to transfer heat to the boiler tube and the application of anything on the element could actually insulate the element and diminish the efficiency of the heat transfer.
The anti-seize doesn't go on the element, it goes on the threads.
Jim - Chris_BryantExplorer III always use anti sieze compound. It is actually good for heat transfer, better than "dry".
- Old-BiscuitExplorer IIIGet a brass brush.....like a gun barrel brush and run it thru the element holder to clean out rust.
Then install new element.......no anti-seize as you want direct heat transfer. - basscatlildaveExplorerThanks its not sliding back in so I thought a little lube may help. I'll fold some sandpaper and hone it a little.
- Ex-TechExplorerI would use caution on the anti-seize.
The heating element needs to transfer heat to the boiler tube and the application of anything on the element could actually insulate the element and diminish the efficiency of the heat transfer. - BTPO1Explorer
Jim-Linda wrote:
Antiseize on element threads will work well. Not sure what gordy is referring to.
Jim
X2 on the anti-seize. JMO - Jim-LindaExplorer IIAntiseize on element threads will work well. Not sure what gordy is referring to.
Jim - gordypigExplorerNever, if it swells it's bad
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
