I have a Dometic RM1350 4 door refrigerator. Yesterday I noticed a little water on the kitchen floor. I went outside and opened the access vent panel and saw things were wet. I shut off the water supp...
Odds are you have a leak in the Icemaker line BEFORE the cutoff. There is NOTHING on your refer that will produce enough water to seep out even if the condensate tube was doing it. Is the water still soaking the outside rear of the refer? Also, has it been raining? could your roof vent be the problem? Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
