dougrainer
Mar 11, 2016Nomad
RV refers will work the EXACT same whether on LP or 120. What can be a variable is the LINE voltage to the RV. If you are in a CG that has lots of RV's and they are pulling the line voltage DOWN, then the refer will not operate as well on 120. Above 110 volts it will work just as well as LP. The BTU heat output is almost identical on LP and 120. For some reason, people think because it is a HOT flame, that is a better source of heat. NOT SO. Even the flame has to have a spiral baffle to distribute the flame evenly around the boiler tube. Doug
