Old-Biscuit
Sep 12, 2014Explorer III
IF you had a blockage in cooling unit it would affect both electric and gas operation......one cooling unit/2 heats sources and blockage is permanent.
Insufficient cooling on gas:
Low gas pressure
Flue baffle out of position
Dirty flue
Dirty burner
Dirty main orifice
You have blue flame........is it centered under flue chamber?
Flue baffle should be 1 7/8" above burner.......too high and not going to get proper heat transfer
Flue tube.....needs to be cleaned......carbon/soot will inhibit proper heat transfer
Low gas pressure
Dirty flue
Dirty burner
Dirty main orifice
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
