- JC2Explorer
k9dad wrote:
Question about refrigerator cooling during preparation for a trip. Does it cool faster when plugged into electric (in my driveway) or just leaving the propane on and cooling that way?
Thanks for any input.
The rv fridges that we have used over the years usually took about the same time to cool down to acceptable operating temps whether on ac or lp. The fins inside the fridge started to feel noticeably cool at 8-12 hrs and after 24 +- hrs, the freezer and fridge were at 0/mid 30's respectively.
Last spring(2015), we did replace our Dometic NDR1062 rv fridge with a Haier 10.2 cu ft residential as the cooling reliability became less than acceptable. We had the install checked for correct specs, installed the Amish exterior coils and finally crossed the line when they developed a leak after 18 months. smkettner wrote:
Propane is faster for me. Gets started before I pull out of storage. No need to plug in when packing.
Not faster. MORE convenient. Doug- Propane is faster for me. Gets started before I pull out of storage. No need to plug in when packing.
- koda55ExplorerWe keep a couple of milk gallon bottles in the freezer and when we are ready to cool the fridge we take them out and put them in the fridge freezer. Helps to cool it faster whether on gas or electric.
- prstlkExplorerIf you take a can of hair spray (don't use it myself as I don't have hair and my barber uses a 1 guard to keep me presentable) if you hold the nozzle down the can will become cold. The refrigeration principal uses a compressor to duh compress a a gas (freon). When that compressed gas goes through the system it releases cold air, and carries off warm air to the coils, and then it starts again. The 2 way rv fridge instead of delivering a cold source removes the heat through absorbing the heat and carrying the heat away from the unit (fridge) again through a coil. The rv fridge uses absorption of heat vs. Refrigeration in the conventional sense. If your not confused by now, I am.
- Kayteg1Explorer II
mrsportys wrote:
The real question is...do you run propane while your driving ( vs having the generator on) ?
- mrsportysExplorerThe real question is...do you run propane while your driving ( vs having the generator on) ?
- TNGW1500SEExplorerI would use the electric and make sure RV is level. Freeze all meat at home in house freezer, then transfer to the RV refrigerator even if not putting that meat in the freezer part. It will help the refrigerator get cold as it thaws out in RV. Make sense?
prstlk wrote:
What's important to note is these units are not refrigerators in the conventional sense. They don't cool but rather absorb heat. The best thing to remember is what ever you put in the fridge, pre cool it. As you travel introduce warm items gradually. Don't put 2 12 packs in and expect cool in 12 hours.
Pre cool your fridge 2 days before your leaving and gradually add the stuff.
Jmho
ALL refers and Air conditioners operate under the same principle----They remove HEAT from an item and the result is COLD. Doug
PS, what is your idea on how a refer operates?- prstlkExplorerWhat's important to note is these units are not refrigerators in the conventional sense. They don't cool but rather absorb heat. The best thing to remember is what ever you put in the fridge, pre cool it. As you travel introduce warm items gradually. Don't put 2 12 packs in and expect cool in 12 hours.
Jmho
38,780 PostsLatest Activity: Jul 20, 2026
