Old-Biscuit
Jun 23, 2014Explorer III
jlscjs wrote:Old-Biscuit wrote:
Check with a meter what DC voltage you have on terminal block backside of fridge with fridge off and with it on
And what does it indicate if there is a difference, should they read 12 volts either way?
Yes.....DC voltage should stay constant.
It will indicate whether you have good dc voltage to fridge and that your dc voltage from battery/converter is maintaining when fridge turns on.
If constant then battery/converter is not problem and problem is fridge controls.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
