My dometic royale fridge isnt working. Eyebrow panel has no lights! Checked and changed all the fuses and outside plug is working as well. Any suggestions would help and thanks in advance!
Check for 12V DC at terminal block where DC wires connect (next to control module in outside compartment) Then follow wires to burner stack and check for DC power coming out of thermodisc.
No DC power....thermodisc has tripped (Opened) which means cooling unit may have leaked/overheated.
If you have DC power then need to check DC power on control module and 3A fuse on board
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
