MrWizard
Oct 26, 2014Moderator
fridge electric heating element 345w, 3amps at 120v
but thats 30amps at 12v input into the inverter..
your 1kw inverter is No problem, but your batteries will only last a few hours
the fridge uses 12v control circuit, but that very small only 1 amp , unless there are fans on the cooling unit
switching from electric to gas on power failure it will last a long time on batteries and propane
but propane fulltime is best, then if shore power fails, the only drain on batteries is the 12v control circuit and the fans..
like i said a long time.. days..unless there are 12v fans involved
even then it will be many hours
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
