pianotuna
Oct 27, 2014Nomad III
Hi Westend,
For the difference in price I'd go with the 2000 watt Pro-Watt if I were going "stand alone".
Unlike Mr. Wizard, I run my fridge as much as I possibly can on 120 volt. Mine is a 3 way, and initially worked well on 12 volt, but doesn't even maintain on 12 volt any more. Draw on the battery bank is pretty much identical between 120 volt and 12 volt at 34 amps. I imagine there is some inverter overhead of perhaps at a maximum 2 amps.
I just finished a trip that extended from Oct 11 to Oct 26 and covered 2500 kilometers (1600 miles). Only on the last night did I not have access to shore power, so I ran the fridge each day on 120 volt powered by the inverter. I also burned no propane for heating.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
