pianotuna
Oct 28, 2014Nomad III
Hi Limoges,
Four of my batteries are 10, the others are 5 years old. It is about having enough battery capacity, and recharging to 100% when ever humanly possible.
Limoges_Camper wrote:
Using it in electric mode, be it in 120VAC or 12 VDC uses up more of the battery's power than the propane does of the total available capacity, thus the effect of using it would be quite noticeable in battery drain.
another reason to not use the battery/inverter is wear and tear on the battery: the more you use it, the less sooner it dies.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
