sealevel_ram's avatar
sealevel_ram
Fridge Power Problem or Not
My motorhome is plugged into 30 amp power in my garage. Have been running microwave and air conditioning for check out.
Today I turned on my Norcold. It runs fine on LP, but when I turn it on electric, my Intellitec EMS goes up to 40 plus amps for a second and then to zero. The load shedding lights go out, and the fridge says "NO AC". (Of course, I don't have any other draws such as the air conditioning activated.)
I turn on the generator and the fridge runs OK on the 50 amp AC.
I know the fridge should not draw 40 amps at start. Fridge problem? Works fine with gen power. Maybe the EMS is not performing as it should. Any ideas?
  • DrewE's avatar
    DrewE
    Explorer III
    MrWizard wrote:
    sealevel ram wrote:
    MrWizard wrote:
    i would suspect a bad 120v heater element leaking to ground aka the metal tube of the heater
    you can turn off the ems, or you can pull out the heater element and test it for resistance between the shell/case and the power leads
    it should read infinity on the ohms scale any lower reading and its defective
    Wouldn't it be bad under generator power also?
    The generator does not have a neutral to ground bond
    Without the bond, there is no neutral to hot short detected because of leakage
    It's a simple test.. pull the heater and test it with the meter
    Chris is probably right, EMS problem, not really 40 amps
    If it's a built-in generator on the motorhome, it should have a neutral to ground bond (that is switched in with the transfer switch). If it's an external portable generator, it generally would not be bonded. If there's an inverter in the mix, things get that much more complicated.
    If the heater element has a hot to ground short (as opposed to a neutral to ground short), what you suggest does make sense. A slow-blow fuse, for example, might be slower than the EMS/circuit breaker in detecting problems. (A GFCI would probably be even quicker).
    At any rate, testing the fridge element seems like a decent place to start troubleshooting. It is a relatively common failure mode, after all.
  • Old-Biscuit wrote:
    Are you running microwave, A/C Unit while attempting fridge on AC?
    As my original post stated, no other circuits are on when I try the refrigerator.
  • Are you running microwave, A/C Unit while attempting fridge on AC?
    EMS is load shedding cause there is only 30A supply.......
    Have you tried just fridge w/o anything else on.......turn off all ac circuit breakers except for fridge?
    Isolate issue! One circuit breaker at a time.
  • I would guess it's an EMS problem- there is a 5 amp fuse on the refrigerator that would blow well before you hit 40 amps.
  • i would suspect a bad 120v heater element leaking to ground aka the metal tube of the heater
