dougrainer
May 25, 2021Nomad
Ivylog wrote:
Proper installation in a slide is critical. Using a mirror determine how much of a space there is between the coils and outside wall... one inch max. Likely there is a dead air space above the top vent.
Still under warranty? Make them install it properly... 1’” of clearance and add a angled baffle at the top vent so there is no dead air space. Fans are a bandaid, except for a NoCold 1200.
The upper Fan inside the upper door on a slide installed refer is NOT a Band aid. I will tout my 42 years as a Trained RV tech and also the fact that over the years I have installed countless upper fans blowing out and have 100% effective better cooling. Makes no difference if a 1200 or a standard 2 door refer Norcold or Dometic. Yes, the baffle to direct air ABOVE the fins curved to get to the door is also critical. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
