dougrainer
Oct 06, 2016Nomad
1. The dino board is BAD
2. You did not connect the wires correctly.
3. Since the problem only happened after the Board was replaced, then the board would be suspect first. Call Dino. Doug
Also, Switching to LP. It will only switch to LP IF the refer is trying to cool. If the refer is at set temp and is shut down due to this, when removing 120 shore power the refer will NOT go to LP until the refer needs to start a cool cycle.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
