TommyC83 wrote:
How about noise. My parents have a class c and you cant hear the fridge run. Mine is on the verge of obnoxious while its running. Maybe its just a lower end fridge? I have very little to compare things to.
IF you have NOISE, that means you have a refer that is probably in a slide room. Is the refer in a slide room? That is because they use a 12 volt fan to push the rear convection air out the top side vent, because a slide room cannot have a roof vent. The do install 12 volt fan on non slide models depending on the refer cabinet parameters. Do you still hear that noise?. If not, then the rear fan may not be operating as it should and that would cause your temprise. Also, if your LP burner is dirty OR the LP pressure is slightly low, that will cause low cooling on LP. Doug
