pianotuna
Jun 20, 2020Nomad III
Hi dougrainer,
If I understand you correctly, #5 setting is (for example) 40 f. So the fridge will be in cooling mode until the fins are 40 f? Then it cycles " off".
But the sensor clips onto the cooling fins. They cool the fridge by convection of the air inside the cavity. So adding a fan may help to even out the temperature in the fridge?
I'm always grateful for your insights into these items. I do know that the Norcold from my 1987 RV appeared to work better than the Dometic in my 2005 RV.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
