CarnationSailor
Jun 20, 2020Nomad
Our Norcold which is usually set at 6 will vary between about 33 and 38 with no correlation to outside temp. (No way to explain it as due to outside temp variations.) I replaced the thermistor, but that had no effect. A couple of years ago, it was getting up into the low 40's so I called a mobile tech. He installed baffles in the rear of the fridge which should have been done when I bought the new trailer and the dealer swapped out the residential for the Norcold. That improved the performance during hot weather and kept it below 40. Since then, have learned to live with the inside temp variations.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
