BFL13
Feb 10, 2020Explorer II
wolfe10 wrote:BFL13 wrote:
.... and the thermistor to high on the right and it still went just under freezing. :)
High and to a side are WARMER areas in the refrigerator and will cause it to run more/operate at a cooler temperature.
Likely not enough to cause your symptoms, but they can affect fine-tuning of the refrigerator temperature.
wnji says it is the other way around on the fins, see above. It seems it is colder high on the fins ( being closer to the freezer above ). Colder is more R. When it gets up to 25ish for R the control stops heating.
However it is true the cold air in the actual fridge goes to the bottom, just to make it all more confusing.
I suppose the 1-9 temp settings are adjustments to R.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
