wnjj
Feb 10, 2020Explorer II
BFL13 wrote:
wnji says it is the other way around on the fins, see above. It seems it is colder high on the fins ( being closer to the freezer above ). Colder is more R. When it gets up to 25ish for R the control stops heating.
However it is true the cold air in the actual fridge goes to the bottom, just to make it all more confusing.
I suppose the 1-9 temp settings are adjustments to R.
In all honesty I don't know for a fact which way you move it for cooling but just trying to explain that the picture was illustrating the fridge target temperature and not the actual fin temperature. If it's the other way, that website you found has it wrong.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
