BFL13
Feb 11, 2020Explorer II
dougrainer wrote:
Moving a Thermister on the fins up or down only changes the result by about 4 degrees. Moving a Thermister is for AUTO Temp refers that have no adjustable tstat. Doug
Not clear on what an AUTO temp refer is that is different.
Not clear if an adjustable tstat is the same thing as the Temp Settings 1-9.
My Norcold 641 runs with no thermistor at all, but just keeps running and getting colder. (But is not in power back -up according to the Temp setting lights which are not flashing.) It does not have that snowflake lamp that says the thermistor is broken or whatever.
I am running the fridge on AC now at home until it gets colder and then will aim my IR temp gun at the fins. Before starting I checked and did see the upper right and lower left fin temps are the same. Will report later on that test.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
