enblethen
Jul 01, 2017Nomad
Vents are pretty much the same. I replaced mine with one that has a slope on front.
I would check to be sure that the refer installation is right. Many have been installed with too much distance between coils and exterior wall. Should be less then an inch.
I used foam board secured to fridge's framework with construction adhesive.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
