dougrainer
Dec 02, 2014Nomad
If NOT leaking, then in that 15 years, all those times (short and long) that you parked un-level with the refer ON, it caused a microscopic blockage on the upper tube area. This is a accumulative process, over the years those small blockage's build up and then one day you do not get the cooling you expect. This type blockage is permanent, you cannot Burp or rotate the refer to fix the problem. The blockage is as hard as a weld and cannot be removed. Years ago when they used to rebuild old units, they cut out the blocked tubing and welded new tubing in place since the blockage could not be removed. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
