Dave_H_MExplorer IIJan 26, 2013Frige Fan?A couple of years ago I installed a dual computer fan in the frige. it worked great and just clipped into the shelf. I have been floundering around trying to find the info again since mine is no...Show More
landyacht318ExplorerJan 26, 2013You can likely replace the just fans in the mounting bracket.You can usually find dual ball bearing fans which will last longer before making noise, compared to sleeve bearing.http://www.frozencpu.com/cat/l1/g36/Fans.html?id=FKLcTDT7
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
