A couple of years ago I installed a dual computer fan in the frige. it worked great and just clipped into the shelf. I have been floundering around trying to find the info again since mine is no...
Oil it! Nothing to loose at this point. Center of fan blade has some kind of sticker or label. Remove it and you should see a hole in the middle. One or two DROPS - in center - of best quality, light weight oil you can find. Run for a few hours with the hole up. Bet you a cup of coffee no more noise. Almost all small muffin fans can be oiled. Good luck.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
