choppered wrote:
Its not a digital thermostat. I did check all breakers. All good. It seems to be a 12v problem. Tomorrow I will run a 12v leed to the thermostat and see if it kicks it on.  I believe the 12v line for the thermostat runs from the front a/c back to the thermostat. I will start testing to see where the power stops. As for the BS demo. The kid new less then I did and the and the camper was cold so no idea if it was running. I didn't fire the heat. My mistake but I was so mad I was wasting my time that I didn't do my duty and go through it.
NOT a Digital tstat?  ALL the Jayco Motorhomes and upper line Jayco Trailers we sell have the RVP digital Tstats. Maybe digital is the wrong word?  LCD screen is what they have. The Power for the Jayco system comes from the 12 volt feed to the LP furnace. There are 4 wires to the furnace. The RED wire should have 12 volt positive. The Furnace reset is AFTER this Red wire power. Doug
