Jakessweetthing
Mar 18, 2014Explorer
Led 67 wrote:Yaj wrote:
You can easily check for 12 volt power with one of these. Much easier to use than a meter!
X2 on the old standby testlight. The test light will tell you wether or not you have power to the circuit or not whereas the voltmeter, directions are simple to understand, will tell you how much voltage you have, if any, in the circuit also once you learn the volt meter you will find many many more uses for it.
Good Luck
OK we have one of these, Performance Tool - Electrical Tester, so will give it a check, let you know,
