Just purchased a 2000 Pace Arrow which has been unused for several years. In the process of reviving it I found it has leaking pipes which are not accessible. My question is does the floor have to be ...
For the leak behind the water heater (been there), I had success by removing the water heater then re-plumbing to avoid the problem joints (I think joints are where most RV plumbing leaks come from).
You can also bypass the bad plumbing by running new lines yourself. Consider flexible Pex, and use good fittings like sharkbite.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
