tboss
May 20, 2013Explorer
If you have to have help and suggestions as to how to remove the clamps then how will you ever be able to retighten them..this is not an area where there is room for a lot of guessing and mistakes. I wld sugest you take it to a garage where some with more experance can do the job rite..there is nothing worse than being 1000 miles from home and discover that you cant fill your tanks cause the filler hose has slipped off the connector on the tank or even worse like a fuel leak that can really become dicey and quick. But if you insist I used a mirrow and several etensions on my 1/4 inch drive ratchet and a flash lite..
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
