stevent1967's avatar
stevent1967
Fuel Line To Generator
I have a 2005 Chevrolet 3500 based Class C (Fleetwood Jamboree). I am installing an Onan 4000 generator to replace the generator removed by the previous owner. They removed EVERYTHING associated with the generator except for the internal start switch and hour meter. I have the install figured out except for fuel line in. The fuel sender in the top of the vehicle fuel tank only has two fuel lines attached. One for vent and the other to the vehicle engine. I don't see how the generator was ever attached to this. There is a "port" attached to the side of the fuel filler neck, down near the fuel tank. Could this be a line into the tank for the generator? Any help would be greatly appreciated!
  • Thank you so much! Before making this post, I had looked up the correct fuel pump for my application, including the RV Prep, and it was my existing fuel pump exactly.
    I knew that port on the filler neck had to be the fuel line for the generator!
    Thanks again!!
    Thanks again!!
    If you don't get fuel out of this connection it is possible that the rubber fuel line attached has deteriorated over the years and needs replacing. If so make sure you get fuel line that is rated to be submerged in the fuel, not all fuel line is.
  • A bit late to the conversation,I just saw it.
    On my 2006 Fleetwood Tioga on a 2005 Chevy Chassis the fuel line is indeed on the filler neck,you can see the hose coming off the port, it goes to the generator.
    Click For Full-Size Image.
    One thing about Chevy,they always do things a bit different.
  • j-d's avatar
    j-d
    Explorer II
    Personally, I Like It! Not as elegant as genny pickup incorporated into the fuel pump assembly, but very easy to rig for retrofits, new genny installs etc. I think I'd want some kind of pre-filter, pre-strainer ahead of the fuel filter on the genset itself.
    Then of course the risk of the pickup line too long/too low, allowing genny to run the tank dry. Pretty practical idea, though...
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
