I have a 1986 Holiday Rambler Presidential! Will not stay running , I have replaced plugs and wires and distributor cap and rotor button both fuel filters and rebuilt carb,cleaned fuel tank replaced e...
Are you certain its a fuel problem? When you replaced the distributor cap did you replace or at least have a look at the rotor? I have seen rotors with a hole burned through them with similar symptoms.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
