I have a 1986 Holiday Rambler Presidential! Will not stay running , I have replaced plugs and wires and distributor cap and rotor button both fuel filters and rebuilt carb,cleaned fuel tank replaced e...
Fuel pump relay is on the left side of the engine compartment mounted to a brace. It only operates for a 5-10 seconds to pressurize the system. The fuel pump power operates through the oil pressure sending unit. It is possible that the circuit in the sending unit has failed.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
