- covered_wagonExplorerThe relay will never be in the fuel tank. It is commonly in the PDC, power distribution center and if you hve a similar relay such as the horn relay you can switch them to see if the fuel pump will run again.
Be careful though.... some will say 'fuel relay' but is for the injection pump if you have a diesel rig.
Best thing is to drop the tank and get rid of the in tank lift pump (not the injection pump) and add you own frame mount lift pump for easy access and changing if needed.
In the tank lift pumps are only guaranteeing that the dealer will get your service when it goes out. Pretty much a planned dealer support item. - LwiddisNomadSend Scott a private message. No need to post to everyone.
