travel_queen_1
Jul 22, 2014Explorer
Gdetrailer wrote:travel queen 1 wrote:
Hello all,
Update; understood, it is a 1984 Travel Queen with a Chevy 454, not sure I am thinking the fuel pump may be in the fuel tank?
I have an older RV that I bought used around a year ago. It has a fair stereo system that works OK when the rig is running, however if you are parked and want to run the stereo no matter if the key is in run or acc the fuel pump will run. Everything is so tight and hard to get to. Has anyone else had this dilemma and is there an easy solutiom?
The fuel pump SHOULD NOT be running anytime your ignition is turned to ACC, period.
Pretty good chance that someone had to "MacGiver" the fuel pump wiring.
Most likely was a problem for the previous owner and they rewired the fuel pump from the Ign/Run to the accessory position.
You may need to locate the shop manuals to find out the wiring schematic..
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
