Nathanbates114's avatar
May 01, 2023
Full Timing with Solar and Shore Power
Hey everyone,
My wife and I just bought a new 2023 Rockwood TT. It came equipped (from the factory) with an inverter, 2 200w solar panels and we added two Lithium Ion Batteries (100ah). I was under the impression that the inverter would work for everything in the trailer but I guess that is not the case. My wife is a travel nurse and we will be full Timing for the next 8-10 years and wanted to save on our electric bill. My question is, should we add another inverter that would make it to where we can use everything in trailer with the solar and lithium ion batteries and then plug into shore power every once in a while if the batteries and solar can't keep up? Or, if we're plugged into shore power, would the solar and the lithium ion batteries save us any money on our bill? It's very confusing to me as I know the solar keeps the batteries charged but I believe once we are plugged into shore power, that will trump our solar if I'm correct. Thanks for any advice and tips. Much appreciated.
  • 120V devices take a lot of power and you have a small solar battery setup. For example a 10A A/C would require the inverter to draw 100A from the battery, hence you have 2 hours of run time plus a few minutes if the sun is out.
    You could save a little but it's very dependent on your AC device usage and DC usage.
    Your charger and solar controller don't trump each other. Each contributes to the house loads and any remaining power charges the battery.
  • Generally, the inverter is not wired to run everything. Heavy power use devices like the aircon and hot water heater are usually not included as most systems can't keep up with those. 400w of solar with 200amp-hr of battery bank certainly are not going to keep up.
    Where solar/battery shines is if you are staying in cool climates where you don't need aircon and you keep your other power consumption to a minimum.
    So what exactly are you thinking of when you say "everything"?
    The next question is how much do you really think you are going to save in electric bills? Most short term stays include electricity, so it's use it or lose it. Monthly stays are hit and miss in terms of using a meter but even so, it's often pretty darn cheap, particularly when you consider the usable life of a battery bank. Assuming you aren't running the air/con & water heater much, $20-30/month for electric wouldn't be unusual.
  • assuming your TT is wired like all of the others your batteries will charge when plugged into shore power. be careful, though. some chargers will continue to pour energy into the batteries even when they are fully charged. be sure your converter/inverter is ‘smart’ (multi-stage) and will transition to a ‘maintenance’ or ‘float’ when the battiries finish charging.
    our MH has a 2000-watt inverter which runs many but not all AC systems, the roof air cond being one. and not all of the AC outlets are connected to the inverter.
    good luck and safe travels.
