tenbear
Dec 22, 2015Explorer
I agree with BFL13. Your converter is doing its job. Some how the converter voltage is not getting to the battery. It could be a circuit breaker between the converter and the battery, maybe you have a battery disconnect switch that is disconnecting the battery, or maybe just a loose wire between the converter and the battery.
Check the voltage at various points between the converter and the battery to see where the 13+ converter voltage drops to the battery voltage.
