dougrainer
Mar 04, 2014Nomad
Mr. Black wrote:
We are not really known for bug related blockages as much in this region. Not saying it's impossible but unlikely. As a matter of fact I have actually found that I get get this furnace to light off immediately if I partially block the furnace exhaust with my hand. It's also unlikely we'd have two trailers doing this same thing at the same time in two different regions.
I have had a few suggest it's a regulator problem but I just don't know. I have asked the dealer to do a LP pressure check with a manometer but I don't even know if they have the equipment for it.
If the issue is not resolved I'll try and get a video of it to capture the sound it makes.
A quick test for a mis-aligned Spark Electrode is the outside hand test. This keeps a larger amount of LP in the chamber that will light. It is also a good test for a restricted LP orifice. This also keeps a large build up of LP and it then ignites. Either way, you have to pull the burner to verify which it is. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
